terminating a process in system exec via ctrl+c
I am running a process in command window which is invoked by system exec. The only possible way to terminate and get back to the main command window is via Ctrl +c. How do I implement it?
ANy idea ...
RY
(3,515 Views)
Accepted by topic author VEEDAY
I solved it... was quite easy.
Create a numeric constant corresponding to the ctrl-key, convert it as U8 and type cast and use the string output and paste in the command prompt.
Works good ...
RY
(3,505 Views)
