test_digital_io_port vi help
HI all,
I'm using ultrasonic sensors that will send a digital high input to the NI-7350 if an object is detected. I'm using the VI attached to read the ports. I've wired one of my outputs to pin 10 of the NI-7350 to test out. But when I run the program code. An error message appeared.
"Error - 70072 occurred at set I/O Port Direction.flx
Motion : The NI motion controller is in power up reset state. Please execute the clear power up status function or VI before sending any commands to the controller. "
What is this clear power up status function ?
(2,359 Views)
Hello.
I think you should have an answer on this thread. JB attached an usefull VI for you.
Best Regards.
Message Edité par R_Duval le 07-16-2008 11:42 AM
Romain D.
National Instruments France
(2,356 Views)
