test for normality
I'd like to test a data set for normality before running a bunch of stats on it, but can't find much on this topic. Can anyone suggest a test for normality?
I haven't seen anything, so I'm trying to write my own test VI. My sample size is small (n=10) so the Shapiro-Wilk test seems like the best option. Finding W from the correlation between the samples' values vs order rank is possible, but I don't know how to get a proper P value from W. Maybe a W-P lookup table exists that I can use, but I haven't found it yet.
Any help is greatly appricaited. Thanks!
-Bayen
(4,811 Views)
There is not an out-of-the-box normality test in LabVIEW... one option would be to compare the histogram of a normal distribution with a histogram of your data.
Histogram VI
Message Edited by CXB on 10-29-2008 02:26 PM
Chris Bolin
LabVIEW Partner Program, CLA
(4,772 Views)
...or the Gaussian Peak Fit VI
Chris Bolin
(4,771 Views)
...the Residue and Standard Deviation outputs of the Gaussian Peak Fit might be helpful.  Just some quick thoughts.
Chris Bolin
(4,766 Views)
Thanks for the suggestions. These are all subjective measures I've played around with, but I'm looking for something that outputs a P value so I can make confidence level decisions.
(4,760 Views)
