teststand operator interface oi
Hi to all,
as Andy advise me in this, I also post my question to LV forum.
Problem:
Into TestStand OI, I have a need to select a directory from several where to select the test sequences to run, but it should be available after the user gives its login&password, and once he has finished its test session he has to deselect and discharge the sequence ran. In this way he is allowed to select a different directory.
I tried to add a stacked sequence and an event structure without success.
In attached the OI used.
JL
(3,013 Views)
Hi Jose,
Can I ask you a couple of questions ?
1) with "select a directory from several where to select the test sequences to run", you mean sequence files instead of sequences ? There's a difference between a sequence and a sequence file, looks like you want to select sequence files it is correct ?
2) If you create a BIG sequence made up with SUB-sequence call to all the other sequences you want to select you can use the standard operator interface to select the run mode (Right click>>run mode>>Force Pass/Fail Skip Normal). Is this a solution to your problem ? If not can you explain why ?
Best Regards.
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(2,996 Views)
Hi FiloP,
regarding your questions, for number 1), I have to have several directories, each one containing Test Sequences files (xxx.seq) addressing e.g. Test_01.seq, Test_02.seq and so on for a specific equipment. The directories regard equipment with similar characteristics. I mean, Eq_01 (dir Eq_01), etc.. So, yes, I want to select sequence files.
Now, for what regards the number 2), unfortunately this is not possible due that into the OI customized, I have to provide other data, regarding the selected Equipment (e.g. Eq_02). Moreover, the way to run the selected Test Sequences could be different in the sense that some should be run one-by-one instead of the other, should be run all together.
I hope I clarify enough.
(2,993 Views)
