text color in subVI
I'd like to change the text color in main front panel which was used in subVI.
To make simple my question, I'm attaching 2 VIs (Version 6.0).
(2,930 Views)
Could not exactly understand your query
And only one vi is attached
(2,916 Views)
In subVI (Property Text Color_subVI.vi), it has a text color property node changing a color (blue or red) - pls see the previous attachment.
I created main VI (Property Text Color.vi) and called up the subVI in it - I'm attaching this VI.
In main VI, I'd like to see the text color property node changing the color.
Hope it clears.
(2,906 Views)
You are setting the property of the indicator that inside the sub VI and not that of the indicator on the main VI
You have to pass a reference of the main vi indicator into the sub vi, use a property node and set its text color porperty
Look at attached modified vi's
Hope this helps
Dev
(2,900 Views)
Thanks a lot~!!!Smiley Very Happy
(2,893 Views)
