text file + combobox
Hi guys,
I'm about to give up on this, I've searched all day about this and no one have the same thing that I want...
I have a txt file that is like this
Using this file I want to create a combobox that its items and values have:
Items | Value
...etc
Right now I'm using Read text from File and Spreadsheet String to array but I can't figure out how to achieve this.
Message 1 of 10
(5,868 Views)
Post a VI of what you have tried so far.
Message 2 of 10
(5,857 Views)
here it is, is not very useful really...
Message 3 of 10
(5,853 Views)
Accepted by topic author lord_nox
You want to write to the Strings And Values property.  I also recommend using the Read Lines option on the Read Text File and then a FOR loop to parse each line (Match Pattern with a tab as the desired pattern).
Message 4 of 10
(5,832 Views)
Thank you so much for the answer, I'll check it tomorrow in college and i'll answer, thanks again!
Message 5 of 10
(5,821 Views)
Hi Crossrulz, I'm making the VI that you send me and I have a little issue (I think)
Is with the array that goes to the bundle, here is the picture...
I create an Array Constant to the Index Array Input, can you please tell me what's wrong? thanks!
Message 6 of 10
(5,788 Views)
Hi nox,
create this array constant directly from your combobox "strings&values" property node!
(This way it will be a typedefinition as shown in Crossrulz' snippet! Btw. you need an array of cluster as is written in the context help of this property node…)
Message 7 of 10
(5,785 Views)
By the way there is no need to recreate the VI.  The image CrossRulz has the VI embedded in it as a snippet.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
Message 8 of 10
(5,773 Views)
Right-click on the StringsAndValues[] input and select Create->Constant.  That will be the array of clusters you should be using.
As an aside, I always find Type Def of an array to be painful for a user.  The contents of the array should be the Type Def (in this case, the String/Value pair cluster), making things a lot more modular and easier to use.
Message 9 of 10
(5,771 Views)
Thanks to everyone, is working! 🙂
Message 10 of 10
(5,747 Views)
