text to bit stream
Thanks to all for the helpful information. As a Labview newbie I humbly ask for help on a (probably) easy problem. Links to tutorials are welcome 🙂
I am now trying to plug the ouput of the Tx portion the shared VI into a sink that is expecting unsigned long 32 bit array. I expect that there is some sort of conversion block for the 16bit integer but I'm having trouble locating it, if it exists. Any help is appreciated.
Paul
Message 11 of 24
(2,675 Views)
I think you are looking for the Boolean Array To Number function, which is in the Numeric->Conversion palette (right next to the Number To Boolean Array function).
Message 12 of 24
(2,656 Views)
can any on plz send me vi of bit to text conversion..!Smiley Happy
Message 13 of 24
(2,606 Views)
Go back and look at message #9
Message 14 of 24
(2,598 Views)
I can think of many ways to do it.  They all depend on what format you want your text to be in.  I suggest creating an example of what you expect as an input and then what you would like the output to be.  Be VERY specific in your example.
Message 15 of 24
(2,596 Views)
i am sending a signal through usrp it is a text signal now when i recieve it i want to convert the recieved signal back to text...!
Message 16 of 24
(2,574 Views)
boolean array to number.
Then take that number and typecast it to a string.
Message 17 of 24
(2,554 Views)
That is not specific at all.  PLEASE GIVE AN EXAMPLE.  What does the text look like?  What numbers are you trying to get out of it?
Message 18 of 24
(2,544 Views)
Hi Altenbach,
really handy VI, just wanted to see if you knew what was up with this though - the input works and converts to binary no problem but cant display on the output...
hope you can help - attached a pic and the vi, weird red dot on the 'byte to array string' on the output side of things too, think its just something to do with the data type
thanks very much! 🙂
EDIT: never mind, i noticed i wired a connection wrong. 😛
Message 19 of 24
(2,378 Views)
hi
i wanted to know that once you converted string to binary , how did you modulate it?
i am trying for real time string to binary conversion and then transmit it  but i am struck.
i will highly appreciate any help.
Message 20 of 24
(2,306 Views)
