text to excel and inserting graph issue?
I have a program that saves all data to a .csv file but is opened in excel.  Everything works fine except when I try to import a graph image using the report generation toolkit.  It worked fine when I just tried it on a dummy .csv file but when I copy the actual test results to the same dummy file it will not work stating there is a conflict with the way the results are imported but I continue anyway.
I am guessing it is the way excel opens and imports the data (comma,tab delimited etc) automatically when the first file was setup on the computers.
I hope this is not too vague but I am guessing I may have to make a seperate .jpg file for each graph I want with the same name.
Attached is a file I would like to add a graph to using the export graph image invoke node.
Any help would be appreciated.
(2,603 Views)
Accepted by topic author BernieSAIC
I got it working by using the save report.vi before I disposed of the report.  Did not need to do that on the dummy file so i am still wondering where the disconnect is but oh well, its working...
(2,576 Views)
