text to .wav file
I am trying to convert the text data to .wav form. I am not sure,if this is the proper way to do it.
Message 1 of 9
(5,876 Views)
Only if the numbers are written in hex form, if you can read them you need to convert them. Check out Text to decimal number.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(5,854 Views)
Hi kulsman,
You can hear that afterwards - just try it! 😄
Btw. it doesn't look "right" when you convert a text to U8 array followed by conversion to DBL array followed by a CoercionDot...
Message 3 of 9
(5,850 Views)
I think my values are in hex. Please the attached text file.
I have tried to play the output, there is just some static noise....
Message 4 of 9
(5,821 Views)
Hi kulsman,
when I rename your songtext.txt to songtext.wav I can hear the (classic quote) words "What is thy bidding, my MASTER!"...
The file is already a WAV file so you can read it using the Wave sound reading VI. No need to read as txt and no need to convert in any kind...
Message 5 of 9
(5,816 Views)
Yeah, the header of the file got me thinking in that direction also, but i got an error when renaming and opening the file. 😕
/Y
Qestit Systems
Message 6 of 9
(5,811 Views)
Unfortunenately, the decryption algorithm needs a text file, so I have to use the text file.
It is interesting that by changing the extension that you are able to play the song. Could it be possible to do the same in labview?
Message 7 of 9
(5,806 Views)
Hi kulsman,
I can load and play the file using simple LabVIEW functiosn from Audio palette:
In LabVIEW the sample rate is wrong (at least in this quick try), but maybe the file is mangled in a weird way...
No, you don't THINK DATAFLOW!
The algorithm expects DATA formatted as string. You can read any file as plain string (which is just an array of U8) regardless of the file format or it's intentions...
Message 8 of 9
(5,774 Views)
Hello GerdW,
Sorry for the late response. I have been out of state for a couple days, but I came back now.
It seems like I could get it to play properly setting the sound format:
Sample Rate:
10,000
number of channels:
2
bit per sample:
8
Message 9 of 9
(5,736 Views)
