text
Ok i need a bit of help.. i need to find a way that a programme reads actual text and numbers from the same file...
I am attaching a file in Exel, basically I want Labview to read B2 to F4, problem being that the contain Mixture of written text and numbers. The idea being that once i have each of those items, i can use each one of them as a variable...I would really apreciate all help that you cna provide...
Regards
Mansoor
(3,012 Views)
Hi Mansoor,
save your data from Excel as csv or tsv (comma separated or tab separated values). Now read the data in LabView using 'Read spreadsheet file'. You will get a 2d array of strings and you can get subarrays to convert them to numbers (or whatever you need).
(3,005 Views)
