the best way to learn labview to get 32 signals from thermocouples? p.s I`m a beginner
I have to set the labview program for the fatigue test of the seal by using the thermocouples. I`ve just studied labview for 20days by myself.The test`ll be in high pressure, speed and temp. I am using pci6031e DAQ, BNC-2090, labview 6.02 .
Could you...? any advice`ll be a great .
thank you.
(2,672 Views)
I just wanted to mention. Make sure you use "Convert Thermocouple Reading.vi", which is located in:
Function palette -> Data Aqcuisition -> Signal Conditioning
This vi is sometimes overlooked. It can simplify a lot your project.
Other than that, look at the following page:
http://www.ni.com/sensors/
Everything about sensors.
Best regards;
Vargas
www.vartortech.com
(2,672 Views)
