the header for datafinder queries
I used Datafinder as a database with TDMS.
In my office, the TDMS files can be searched in any properties.
But one PXI has a problem in searching the properties (for example, _NumChannels) in the file level.
(Only using <>, the query result was displayed and no problems in channel and group level.)
However, other PXIs and computers didn't show this problem.
NI engineer recommend to install LV again.
(My computer LV: 2009, the specific PXI LV: 2009, tested computers and PXIs: 2011)
As a solution of future problem, I'd like to know what kind of trouble in PXI can show current trouble.
labmaster.
*) All tests were done with the enclosed one TDMS file.
(2,433 Views)
Does the problem persist if you re-index My DataFinder on your PXI system?
(2,413 Views)
Thanks for the reply.
I reset the index option in Datafinder but useless before.
(I will try to reset again.)
However, can you identify other items to be checked in the computer?
labmaster.
(2,400 Views)
I configured Datafinder folder to new folder again. But the same problem.
Can you guess what is the next do I have to check?
labmaster.
(2,385 Views)
