the objects on the front panel moved when using different resolution monitors
Hi
The objects layout is very good on my development PC (1920*1080)
But They are all moved on the running PC(1024*768)
I have ticked the two box in the Window Size
Please help me how to fix this problem.
(1,613 Views)
Why do you want to use different resolution? Why not keeping the one that works?
(1,582 Views)
Hi Hong,
Switch off BOTH tickmarks in this dialog: don't scale the frontpanel automatically!
Then design the frontpanel to fit for the lowest supported monitor resolution…
(1,568 Views)
