the output string in RS232
Dear,
My labview6 VISA code is controlling a equipment by RS232.
In first running of the code, output characters were read incorrectly. If the desired result is "12345-678", the appeared string is "345-678123" with some offset.
I don't know why the string is moved inconsistently.
(Maybe, I guess it comes from a remained string in buffer.)
I used VISA buffer flushing routine but it was useless.
Could you recommand any skills to read the string correctly?
(3,375 Views)
In assume you are using serial VISA
The normal sequence of RS232 communications that I use is
1-Flush communication buffers both read and write
2-Write the string
3-wait for some ms (depending on the instrument used)
Then read the bytes
and I never had problems with that.
(3,375 Views)
When possible I enable the termination characters this usually helps. (Not all equipment will provide a termination character but it would be great if it did.)
(3,375 Views)
Very thank you for the reply.
Although I resolve my problem by using termination character, I would like to know your comment.
Could you please attach or give some example codes for flushing the buffer?
(My email is poyntor@yahoo.com)
Thank you again.
(3,375 Views)
From LabView Help:
"termination char calls for termination of the read operation. The read operation terminates when the termination char is read from the serial device. 0xA is the hex equivalent of a linefeed character (\n). Change the termination char to 0xD for message strings that terminate with a carriage return (\r). "
I usually Do not enable the termination character. Depending on the command, and what to expect to read, I read the whole available bytes and handle expected strings with proper parsing (after the command is sent, I wait for enough time before read, to make sure the device responded and outputted its data).
And I "Flush the Buffers" before I Write a command. I had an application where if I do not do that, I got er
rors (may be it was device specific).
attached is an example vi for flushing communication buffers
(3,375 Views)
Hi Dr. Imad,
You said you waited a few ms before
reading the rs232 port. How do
you code this in labview? How do
I make labview wait a few ms before
I do the reading?
Thank you,
Van
(3,375 Views)
