the value must be recorded
hello sir/madam,
i am a newbee in lab view ,i want build a program to write the data of a daqmx read to a tdms file such that the recording must start only when i press a key and stops when i again click the same key ,please help
Thanks regards
Ayush Ghosh
(2,379 Views)
Accepted by topic author shankey
Hi Ayush,
This should not be hard to achieve. Would you like it to be when you click a button on the Front Panel? If this is the case then you could wire a Boolean Control to the input of a Case Structure and only have the Write to TDMS execute when the Boolean status is set to True. Is this what you require?
Kind Regards
David B
National Instruments UK
(2,377 Views)
can you please send me the vi file it will be really very helpful to me
Thanks regards
Ayush Ghosh
(2,375 Views)
 you please send me the vi or png file to for better understanding
(2,364 Views)
Hi Ayush,
There is a great example which shows a possible way of doing this that you will be able to interpret to do this for a TDMS file format.
I hope that this helps.
David B
(2,348 Views)
