Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
the waveform is reverse, how to correct
sales@wavesourc
e.com.cn
Member
10-31-2002
07:59 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
the waveform graph on ADVANTEST R3265A is reverse , how to correct it , which node to use ,maybe OK.
0
Kudos
Message
1
of 3
(4,038 Views)
Reply
Re: the waveform is reverse, how to correct
Ben
Knight of NI
11-01-2002
06:07 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Try clicking on the X-scale maximum and minimum values.
Make the max smaller than the min and it should plot in the reverse order.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 3
(4,038 Views)
Reply
Oleg
Active Participant
11-01-2002
06:22 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
another solution is to use
"Functions -> Array -> Reverse 1D Array.vi"
Good luck.
Oleg Chutko.
0
Kudos
Message
3
of 3
(4,038 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
