their is no tools in control design and simulation its blank
their is no tools in control design and simulation its blank. i saw same  question asked before  and found a solution that if we install 32bit labview then all options will be avilable . i  have installed 32 bit labview but the result is same . plzzz help me thanx in advance.... lab.jpg
(3,593 Views)
In what order have you installed the tools?
You need to install LabVIEW first, then install the tools.
Do you have license for that tool?
(3,573 Views)
now im in 7 days trial version . i can use it in trial version right???
(3,570 Views)
Accepted by topic author asit619
Yes, I think so that it is possible to use that tool as a trial.
but you have to install it after you install LabVIEW.
(3,553 Views)
ok its solved now thanx  🙂
(3,547 Views)
So what did you do to fix it?
(3,541 Views)
i havent installed the tool kit  for 32bit labview. in labview 64 bit after installing aslo the moudle is blank . so best is to install 32bit labview
(3,535 Views)
