thermopile
labview is not allowing me to enter a maximum signal input range value of 1000 degrees celcius...I want to do this because the 10 junction  thermopile that i am using multiples the temperature reading by 10...for example a reading of 25 degrees will read 250...and labview does not allow values above 100..could you suggest any ammendments i can make to the attached block diagram to divide the thermopile reading by 10?? PLEASE HELP!!!
(3,853 Views)
I have to admit I never heard of that before reading your threads.
Are you sure it uses the same mapping as a standard TC?
If it does not hen the raw voltage shoould be measureed and apply the proper mapping.
Don't know if that helps,
Ben
(3,830 Views)
Hi 1q2w,
What thermopile are you using exactly? I think it would benefit both myself and Ben as then we can have a look at it ourselves. Would it possible for you to provide a link?
Ben rightly questioned the mapping of it so it would be interesting to see some specs.
Kind Regards
Michael
NIUK Application Engineer
(3,798 Views)
You can read the thermopile voltage and the cold junction temperature (voltage) seperate and do the math by your own.
read the CJ temp
read the TP voltage (multiple times , filter) divide by 10
use the thermocouple reading vi to get the temperature
The TC formulars are somewhat buried, however quick drop is your friend 🙂
Greetings from Germany
Henrik
LV since v3.1
(3,790 Views)
