third party daq configuration
Hi all,
How to configure third party DAQ (i am using HBMMGC plus ML01) in labview ?
thanx in advance
Every Expert was once a Beginner!!
Message 1 of 8
(3,290 Views)
@PROing wrote:
Hi all,
thanx in advance
Read 3rd party DAQ manufacturer's documentation.
Message 2 of 8
(3,285 Views)
hi, thanx for the reply.. in that documentation, they have mentioned only abt the configuration with their own firmware CATMAN but no idea how to do with NI LabVIEW..
Is there any common method of doing for all third party daqs?
Message 3 of 8
(3,282 Views)
No, there is no common method. I would suggest you start with the example that comes with the driver. Note that it is not an NI supported driver.
Message 4 of 8
(3,273 Views)
Not NI supported driver!!!! 😞
then will this be compatible with LabVIEW? I mean, with this DAQ and its driver, do i have chances to acquire datas with labview programming?
Message 5 of 8
(3,254 Views)
Not supported means that NI did not write the driver and will not do any bug fixes. You can certainly use what is there. Have you even tried the example?
Message 6 of 8
(3,246 Views)
i searched for the example in Find Examples - Hardware I/p o/p - instrument drivers, but its not there for hbm mgcplus inst driver..
Message 7 of 8
(3,243 Views)
Look in the top level llb. It might also be on the palette, I didn't look. It's mentioned in the readme that is part of the download.
Message 8 of 8
(3,235 Views)
