third party device communication (technifor)
hi ...
i currently working on project that is i have to communicate engraving device(thechnifor) to host PC  via TCP IP but i unable communicate with that device  in tcp read tool produce error The network operation exceeded the user-specified or system time limit  same thing happen when i try with visa tool read write tool.But it is working NI MAX TCP IP visa test panel  i can send and receive  command via that test panel.. error occur connect via lab view
sorry for bad English
thanks
(2,881 Views)
Accepted by topic author RoBo_k
Apply a proper termination character to your command when sending it. The VISA Interactive Control panel behaves mostly like a terminal adding this termination character automatically as that is what most interactive commands require. When using the TCP/IP nodes directly LabVIEW does not limit you to talk to only specific devices but leaves everything up to you to program explicitly.
Depending on your device you want to add a line feed (\r), carriage return (\r) or a combination of both (\r\n). You can either get these constants from the string palette or add them yourself to a string constant by right clicking on it and select "\ Codes Display"
Rolf Kalbermatter  My Blog
(2,869 Views)
thanks for reply
i give proper termination char in my cmd like "ls\r" .
i able get this from visa tcp ip test panel which give a list of files in that device.
unfortunately unable get output via in labview help me that case ..
when try to sent a cmd labview and cmd sent and get return count from tcp ip or visa tool but try to read for that cmd time out comes ...
(2,864 Views)
