third party hardware without driver
Make sure you choose correct settings for the serial communication, that is
Baud rate, Parity, Stop Bits, Flow control etc...!! so you want to check compatible settings in the user manual of third party hardware.
Next, you should definitely give a try with hyper terminal software before trying it with LabVIEW.
Share you code if possible.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 11 of 12
(528 Views)
the following explain the fundamentals of serial communication
Serial Communication General Concepts
Message 12 of 12
(520 Views)
