three analog outputs by using NI USB 6211
Hi
I am doing a project and want to generate 3 analog outputs simultaneously. I dont know which hardware should I use to interface LABVIEW with the instrument.
Need suggession..
Thank you..
(3,136 Views)
Hi khpp,
your USB6211 only supports 2 AO channels as is written in the specs.
You might use the DO or CTR-out channels (with some additional hardware) to "simulate" an additional AO channel.
From what you have told us you should only need an USB cable to connect your PC with the USB6211…
(3,119 Views)
If you are looking to replace the 6211, click on Products at the top of the page. You have not given nearly enough information for anyone to recommend something specific.
(3,108 Views)
At what rates will you need to update the outputs?  How much time is allowed between value changes?  Can you get away with using one DAC and muxing the output with a non-simultaneous output card?  What output voltage and current capabilities do you require?  What form factor do you need?  Is there a budget?  Is there a specific platform in mind?  How will these outputs be used?
(3,025 Views)
