three curves in the same grafic.
I need put three curves in the same graph.
with control of velocity
Can you help me ?
in anexo I sent the file with problem
Thank you very much.
Juscelino.
(2,723 Views)
Like this?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,711 Views)
Can you help me ?
Juscelino.
If you need to display three plots in one graph, right-click on a graph, select Properties -> Appearance and change the "Plots shown" value to 3. Then bundle three data flows and wire it to the graph in your block diagram.
And what exactly do you mean by "control of velocity"? Do you have delay in mind? If so, use "Wait Until Next ms Multiple" vi from the Timing pallete and wire a control to it.
Juscelino.
Maybe it's only me, but I can't find it.
Message Edited by Giedrius.S on 02-09-2010 03:45 PM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(2,709 Views)
Hi!
Maybe three waveforms with different number of points sould be shown?
Yes, Juscelino, revealing your file (vi, to be correct) would be nice.
Regards.
(2,705 Views)
