three phase simulation using labview
i need help
i need this project
plz help me
(6,440 Views)
Hi malek,
what kind of help do you need?
What do you want to simulate? Do you just want to display 3 sine waves with a phase between them?
Please mark double posts on your own! Or even better: avoid double posts at all!
(6,429 Views)
Description du projet
-produce 3 sinusoidal waveforms 120 degree apart and design on signal graph (phase voltage)
-provide a slider to vary frequency from 50 Hz
-show the three line voltage an signal graph
(6,406 Views)
Hi malek,
LabVIEW comes with ready-to-use signal generation functions. There is also a signal generator that outputs sine waves with adjustable frequency and phase: use 3 of them (or even better: use one of them in a FOR loop).
Then display the waveform array on a waveform graph - easy as it sounds.
When you have problems with all this: NI offers a lot of beginner resources to LEARN LabVIEW. LabVIEW comes with a lot of example VIs. Read the help, take the courses…
(6,399 Views)
Ahh, smells like homework 🙂
look at the signal generation vis , read the help for the vis ,  look at the examples for the graphs ....
Greetings from Germany
Henrik
LV since v3.1
(6,393 Views)
