three position digital switch
Hi everyone,
I would like to build a three way digital switch, a rocker that is true when up false when down, but comes back to a neutral position.  Imagine a trim switch on a motor boat.  Logically, I can do this with two push buttons that switch until latched, but on the front panel this would result in two buttons.  I would prefer one button.  I notice however that the factuory LabVIEW rockers have only two positions.  Is there a way to modify these rockers into a sleek, three position switch on the front panel?  I can easily enough wire the block diagram...
Brad
(3,225 Views)
Here is another thread where they are discussing a three way switch.
http://forums.ni.com/ni/board/message?board.id=170&message.id=118943&query.id=70599#M118943
Maybe it will be helpful.
(3,203 Views)
Do you have LV8? Sounds like something suitable for implementation as an XControl.
(3,193 Views)
Thanks for pointing out that other thread - nothing hit when I searched for three-way switch this morning.
(3,187 Views)
