three way switch?
is there a three way switch available in Labview GUI? I need it to control the motor of an observatory dome. Currently, the when the manual motor-switch is pushed to the right, the dome rotates clockwise and anti-clockwise when pushed to the left. The center position of the switch is for the off position. If there is no such switch in labview, how do i go about designing this?
Thanks.
(7,401 Views)
kohokoho;
Check out the followings:
Using a 3-State (3D) Switch in LabVIEW
How to Create a Three-Position Vertical Switch
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
(7,401 Views)
http://www.openg.org/tiki/tiki-index.php?page=3+Way+Switch
(7,401 Views)
