tick in xygraph
Sometimes, I had a trouble in configuring of tick mark in xy graph by changing of property node, xscale range.
I would like to check the property of x scale (tick mark of XY Graph) is copied to new destination (error plot).
Can you check why my code (tick increament.vi) is not working?
Is it a bug in Labview 2018?
labmaster.
(1,574 Views)
Try setting X Scale->Marker Spacing -> Uniform - or set the XScale.UniformMarker property to True - and see if it's what you want.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,555 Views)
Thank you for the reply.
You are right.
I didn't figure out the option was changed.
(1,550 Views)
Some controls have so many properties that one gets lost sometimes.
Paolo
(1,545 Views)
