time changes when sent via shared variable
I am trying to send time data to a client PC using a network published shared variable.  I read the time data from the host PC via the Get Date/Time In Seconds Function then use the Type Cast Function to convert the time to a SGL 1D array. The data associated with the time is already in a SGL 1D array.  I use the Build Array Function to combine time and data and then write the new SGL 1D array to a network published shared variable on the host side.  On the client side I split the array to separate the time and data and use the Type Cast Function to create a timestamp to display.  The time displayed is exactly 7 hours off from the host.  Minutes, seconds, and date are correct only the hours are wrong.  I do not have this problem if I do the same process on the host PC.  Any ideas why?
(2,680 Views)
I bet you are in either the Mountain Time Zone of Pacific Time Zone.  Not sure, and too lazy to look it up.
My hypothesis:
Somewhere, your software is interpreting the local time as UTC or vice versa.
Solution:
Make sure you are always in UTC and add the correct amount for the time zone or something like that.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,670 Views)
