time/date string to timestamp
Hi John,
and why do you mark your answer as solution then? Smiley Wink
Message 21 of 27
(2,816 Views)
Gerd,
I know this is an old post, but how did you get the timestamp in that cluster format?
Jim
Jim
LV 2020
Message 22 of 27
(2,658 Views)
Look in the timing palette.  You will find a Rec Time to Timestamp and visa versa.  I don't have LabVIEW with me, so I'm a little shakey on the exact wording of the funtion.  Anyways, those functions will convert a huge cluster with month, day, year, DST?, seconds, fractional sections, etc. into a timestamp and back again.  You can right click on one of those inputs/outputs and create a constant.
Message 23 of 27
(2,652 Views)
Maybe my pallettes are messed up.  I have a number to timestamp and date/time to string, but I can't find anything that uses that cluster.
Jim
LV 2020
Message 24 of 27
(2,639 Views)
use the quickdrop and search for "Date/Time To Seconds"
Message 25 of 27
(2,632 Views)
Hi Imtis,
your "Time" palette should look like that:
Use the marked function...
Message 26 of 27
(2,622 Views)
Thank you Gerd.
Jim
LV 2020
Message 27 of 27
(2,611 Views)
