time/date string
I would like recover informations about the last utilisation (date and hour) of one user but I don't know how.
In my program the user enters the name of the person they are looking for. The person sought may be used multiple times within a day or even in the year software Labtech or Adam. I would like to recover the date and time of last use of the program for the person sought.
I try with the "format date/ Time string" but it returns me the same date of my tests.
Would you have an example
Message 1 of 13
(4,284 Views)
Do you have a working or semi-working vi you could attach? Or are you asking for ideas?  You could save the last usage to a .cfg or .ini file using the Config File VIs.  Then when requested, you can read the last used data.  What type of program structure are you using?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 13
(4,283 Views)
Here my sub VI.
I manage to recover the name of research users but not the date of last use.
Message 3 of 13
(4,275 Views)
Excuse me, with the folder it's better
Message 4 of 13
(4,274 Views)
I think this will give you waht you are looking for. You may have to reformat the date but I think this is what you asked for.
Tim
GHSP
Message 5 of 13
(4,254 Views)
no it is not good because if I enter the name of the user calling "sarah" I get the date of 02/31/2012 or she uses the software for the last time on 11/09/2012
Message 6 of 13
(4,248 Views)
Explain further what the problem is.  Are these dates coming from your text file?  You may have to modify the bd of aeastet's VI slightly to get it to do what you want.
Message 7 of 13
(4,232 Views)
In fact, I would like to recover the date of last use of the software for different users (the latter did not necessarily use the software at the same time) which are in the file.
Depending on a user enters, it should display its last date of use.
For example the user "sarah", I would show that the last time she used the software was on 11/09/2012.
Similarly if I enter the name "try30" I would like to see 02/31/2012.
What do you would like mean?
Tkanks
Message 8 of 13
(4,222 Views)
 Create a login VI so you can track who is using the software and when.  Log these users to a log file upon exit.
 I mean, from your last post, I assumed the problem you were describing was from aeastet's VI.  He did say you would have to modify the date format (which is not your problem), but these dates are coming from somewhere.  The file?  I don't know.  I can't run it since I don't have LV11.
Tkanks
Message 9 of 13
(4,217 Views)
Ok, thanks I will try this.
You will find in my file version 9 normally.
Message 10 of 13
(4,208 Views)
