time delay probelm in data aquirsition of voltage measurement
I am measuring voltage using NI DAQPad-6015. Without time delay loop, I can get the data. But what I want to do is to compare the data with that of following moment.
The delay time loop is used to aquire the next moment data.  With this loop, it just stay at DAQmx AI Voltage. What's the problem?
Attachment is my program.
Message 1 of 11
(4,124 Views)
And I use software LABView 7.1 .
Thanks in Advance
Message 2 of 11
(4,116 Views)
You can't see any measure because your  are runing first the funcion Daqmx Clear Task, this function clears the measurements you take..
I send you the next image. I hope this can help you..
Best Regarts Frank..
Message 3 of 11
(4,110 Views)
Got it. It works. Thanks a lot.
 BTW: what are the differences among Wait(ms), Wait Until Next ms Multiple , Time Delay?
Alyssa
Message 4 of 11
(4,090 Views)
And it is supposed that if the difference of two data is less than 0.05, it will stop aquiring data. but when the program executes, it won't stop. what's the problem?
Alyssa
Message 5 of 11
(4,086 Views)
does anybody know about this? I am waiting online. Thanks
Message 6 of 11
(4,078 Views)
How did you modify your VI? The first one you posted did not work at all so I assume you reworked it. Post the latest version.
Message 7 of 11
(4,075 Views)
Thank for your kind reply. Here is the latest version.
Message 8 of 11
(4,072 Views)
With simulated data, it stops for me. You have your limit set to .01. As long as consecutive measurements are with that range, the VI will stop. Maybe you should or the stop condition with a front panel Boolean and a timer. At least then you can stop the while loop without clicking the Abort button.
p.s. The way that you are creating the array that gets passed to the Write to Spreadsheet File is not necessary. Just wire the value from the DAQmx Read to the edge of the while loop and on the exit tunnel, select Enable Indexing.
Message 9 of 11
(4,069 Views)
Thanks Dennis
Truely it works. One more question: as you suggested I wired the write file function with the while loop. but why the output data is only one. what I want is to storage all the data before it stops.
Thank for your help
Alyssa
Message 10 of 11
(4,054 Views)
