time delay while writing data in serial communication
Hi Shubhlaxmi,
if you have the range you can directly connect a property node to this reference. Use the "value" or "value2" property. Why do you need to save data back to the excel file? Why don´t you make every calculation in labview?
I changed your code, so that you can read all values from you specified range. See the attached picture.
Mike
Message 11 of 11
(375 Views)
