time domain calculations
hello,
simple speaking i have a time domain signal that is acquired. Forexample this signal contains :_
1) 1000 samples
2) scan rete of 10Kh
now if i had the above as an experiment and then i do say 100 of such experiments then what i need is to be able to add the results (1000 samples) together
therefore
If
exp1
t=1 value 1
t=1000 value=1000
then second experiment
same thing... but in then end summing it so that i sum all the values in t=1 then all the value in t=2
so the final result looks like
having one time series that si the summation of all the 100 exp...
i hope this makes sense, can anyone let me know how to do this? I tried to use time domain analysis and using but it keeps results for all experiments which i do not need.
thanks
(2,974 Views)
Given your example data, and assuming you got the same data on every run of the hundred, then your 'single time series' would look:
t=1 value=100
t=2 value=200
t=3 value=300
t=1000 value=100000
if that's the case try coding up the attached picture.
-Good Luck.
(2,960 Views)
It is most efficient to setup a shift register and add new signals as they arrive. The shift register contains the sum.
The attached example shows one possible solution. (For the display, I divide by the number of scans for nicer scaling).
(2,953 Views)
