¿time elapsed with lv6?
Hello
I'm writing an application with LV 6.02 and I  need a subvi that tells me if an amount of time is elapsed.  With LV 7 it was easy, just adding the "Time Elapsed" module.  But this element doesn't exist in LV 6, so I have created something similar using the lv2 variables concept.  But I  have a problem.  If I use it at the same time in two different places, I can't use it to measure two different time intervals, because all its internal variables get the same value (lv2 variable).
The vi that calculates the elapsed time and an example are attached
Any idea about how to solve this issue?
Carlos Arcediano del Amo
(2,699 Views)
You can make your subVI reentrant. This is set from VI Properties>Execution.
(2,698 Views)
Hello, Dennis
It has worked perfecty, but...  ¿is there any way to make some variables "reentrant" and the rest "not reentrant"?  I want to reset the counter with some values in a part of the main vi and use this values when calling the counter in an other part.  And I want to reset the counter multiple times with different values.  I know this behaviours are excluding if I make the vi (not) reentrant.
Any idea, or is it impossible?
(2,688 Views)
Hello
it's been better to redesign the vi that uses the chronometer that I have posted, and it works as a reentrant sub-vi.
Thanks for all
(2,673 Views)
