time interval in Labview Signal Express
Hi. I'm new to Signal Express and Labview 2010! We are acquiring voltage vs time data via DAQmx (NI 9215). Is there a way to change the time interval between data points? I think the current value is 1 ms. I have tried to look into recording options but so far I have not figured out a way to do this. Thanks.
(3,934 Views)
This is probably easy but most of us old-schoolers in the LabVIEW forum don't use Signal Express.  You might want to post your question over here:
http://forums.ni.com/t5/SignalExpress/bd-p/380
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,928 Views)
Thank you!
(3,925 Views)
I got curious and it is actually easy:
Add step, Acquire Sgnals, DAQmx Acquire, Analog input, Voltage (or whatever).
In Configuration tab set Acquisition Mode:
     For 1 Sample (On Demand): set the sample period directly (it is software timed).
     For Continuous or multisamples:  Samples to Read / Sample Period = Sample rate  (e.g. 100,000 / 10) = 100,000 samples collected over 10 seconds =        10KHz sample rate.
(3,919 Views)
