time of loop...
Hi!
My vi, contains a while loop that reads a serial port in each cycle.
Depending on the answer, a process begins but duration of process is greater than the loop time. I must maintain the run time of loop, for that reason I cannot introduce the process within of while loop.
I have thought to put within loop, a call to vi that contains the process, using a invoke node, with run vi method.
Somebody could recommend another method to me and comment the improvements.
Greetings.
G.Garrigos.
(2,757 Views)
Hi Garrigos,
have you heard about the Producer-Customer-Pattern? Or about queues?
Both are often discussed here in the forum! And there are several examples delivered with LabVIEW.
(2,741 Views)
