time on x axis of waveform graph under 0,1 s
Hello I have problem with time on x axis. I am measuring voltage from torque tranducer on y axis and time on x axis of XY graph.
If my while loop is acting on every 100 miliseconds I get correct data.
But if  I my while loop is acting on every 8 miliseconds I get data like this. (see my attachment).
Does anbody know how to display the correct time on x axis?
Thank you for your suggestion and answers.
Message 1 of 20
(4,313 Views)
In the title you say "waveform graph" while in the post you mention "xy graph". What is it?
What is the format of the x-axis?
How do you determine or measure x? What is the datatype of x?
Can you attach some simple code that reproduces the problem with simulated data?
Message 2 of 20
(4,307 Views)
Sorry It is waveform chart. Format of x axis is absolute time system time format 3 digits under properties of chart.
I measure voltage with 2 samples and 2000 Hz sample rate.
I have attached some code ODZIV NA STOPNICO is that graph.
From block MER NAV I measure voltage (=TORQUE).
Message 3 of 20
(4,290 Views)
I did my program on help of that program.
Message 4 of 20
(4,281 Views)
Well, a chart has only one x0, so why are you rewriting it to the current value with every iteration?
Set xo and dx once and feed the chart a single cluster containing your two scalars. Don't build arrays with one element and construct waveforms!
Message 5 of 20
(4,280 Views)
I did not undesrstand what to do. So I have two values 1 value and 2 value both on y axis. x axis is time.
How to connect them without build array.
Here is my small program.
Message 7 of 20
(4,266 Views)
You already do, in the upper part of your diagram (using bundle)! The rest you can do as in my example. (Forget building waveforms).
Message 8 of 20
(4,263 Views)
Ok I tried that. But what bothers me is that firstly I can not save time x axis in notepad as before.
Secondly the time which I get is going forward and I get strange results (see my attachement).
What time format would be the best for representing on X scale?
Message 9 of 20
(4,241 Views)
Hello !
I tried also with block elapsed time and get the same results.
If I set while loop on every 0,1 s I get right results.
But if I set time of while loop on 0,01 s I get double points.
here is my program
any suggestion?
Thank you.
Message 10 of 20
(4,220 Views)
