time out in event structure.
Recently, I study the design pattern.
I used all events in one event structure.
Usually, "Go button value change event" and "Time-out" need to acquire some data for a long time via RS-232.
To have responsible UI event, therefore, I would like to put "Time-out" outside event structure using another while loop in parallel loop scheme.
My question is how to deactivate "Time-out" when some UI event is fired and activate Time-out in case of completing UI event without any confliction of RS-232 communication.
In addtion, some variable such as VISA port should be updated in outside event structure.
(2,764 Views)
You are on the right track. Move the operations that will take a long time to a second parallel loop and pass the data back to the GUI event loop using a queue, functional global, or even a user event. In terms of how to implement this functionality look at the producer/consumer and master/slave design pattern templates.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,744 Views)
