time shift
Hi all,
hope someone can help me with this problem, I'm supposed to perform a time shift for my signal however it does not work..
I have an original signal which I need to do a time shift using DFT (Discrete Fourier Transform)
I had used 1D fourier interpolation.vi  to do DFT but 'm not too sure whether this is the right .VI to use. If it is, is there any better .VIs which I can use?
Can someone please help me with this problem, having a time shift by using DFT.
Thanks a lot in advance!!
(3,488 Views)
Your code makes very little absolutely no sense.
  • You are doing a Fourier interpolation with n=1, which gives you the input back as output, so why even do it?
  • Your use of Y[i]=X[i-n] is truly ridiculous. have you even looked at the online helf for this function??? You wire a waveform to the "shift:n" input, which actually expects a single integer.
Can you explain what you are trying to do? Is this homework for school?
(3,470 Views)
Hi altenbach,
Ya you are right, it's for my school work. My lecturer wouldn't want to give more guidelines for me that's why I'm looking at this forum for some help.
Firstly, I would like to apply the DFT to the input signal, as I had mentioned earlier and then perform a time shift.
At first I had used fourier transform.vi to perform DFT but the output signal looks pretty weird.
By right when I were to apply DFT to a signal, I should get a output signal as the amplitude domain right?
(3,455 Views)
Hi all,
May I know how can I do a simple discrete time fourier transform first? Can amend the program which I had sent out earlier for me to compare at least I know what I had done wrong. I've tried writing a formula manually, used the Interpolate 1D fourier and FFT.vi(s) but it just seems that I'm wrong everytime.
What I understand is, by applying fourier transform signal, I should be getting a frequency response graph. I did get a frequency response graph earlier, however when I calculate it with respect to the values I'd set to perform the operation, it's wrong again.
Please find attached my revised program and your superb advises, a million thank you in advance.
(3,415 Views)
