time stamp bug
The timestamp indicator should report 00:00:00.000 1970-01-01 however it reports 00:59:59.000 1970-01-01.  Any other year than 1970 and this problem does not exist.
Could someone verify this?  Please see attached code.
Message 1 of 17
(5,158 Views)
I don't see any problem...  See image below:
Message Edited by JoeLabView on 07-02-2008 10:10 PM
Message 2 of 17
(5,142 Views)
What's your LabVIEW version?
What's your local timezone?
What's your OS?
These things can all be the source.
Please add.
Ton
My LabVIEW Ideas
Message 3 of 17
(5,127 Views)
I get the value differently, but slightly in a different way. Smiley Happy
I dont know exactly if it is a problem on the first hand. Smiley Indifferent
I m in India, so GMT + 5.30. Are you somewhere from Europe?
See the attachment.
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 17
(5,120 Views)
I think you have to make the UTC input to True, to get rid of the problem.
Message 5 of 17
(5,117 Views)
It seems that parthabe has exaclty the same problem although different due to timezone.
Setting UTC TRUE does NOT solve the problem - it just creates a new one as I do not want UTC time !!!!!
LabView:  Version 8.5
OS:
Message 6 of 17
(5,103 Views)
OS:  Windows
Message 7 of 17
(5,104 Views)
OS:  Windows XP,
Message 8 of 17
(5,104 Views)
Sorry about the last post 3 times???? No idea about that one either?!!!
Labview 8.5
Window XP SP3
Timezone is GMT+01:00
Message 9 of 17
(5,100 Views)
It just gets weirder - I changed timezone to GMT +10:00 (same problem).  Does anyone know why the summertime would influence the result?
What I need is to convert the time stamp on the left (cluster) to timestamp on right (time stamp indicator).  What it says on the left is what it should say on the right.  Does anyone know how to do this (and that that it will still work both summer/winter and in all timeszones)?
Message 10 of 17
(5,096 Views)
