time stamp problem
hello, i made a code to read data from table using time stamp duration but the problem is that i am unable to read the desired result using time duration
For example: 2 hour on the date 25/07/2017 from the table
but i was unable to read it,the reason i found was that the time stamp i was getting to compare within the duration i have selected was not correct.
if anyone of you would sort it out that would be really grateful,thanks
(2,916 Views)
Accepted by topic author ransher
Check your string that you make when you concatenate the date with the time, it looks like "25-07-201710:58". You need to add a space so it looks like this "25-07-2017 10:58".
When you scan from string, your time is not exactly in the %T format, so you have to specify what your time looks like. Your format string will look something like this "%<%d-%m-%Y %H:%M>T".
(2,894 Views)
