time stamp to sample data
Hi, I would like to attach a time stamp to acquire data. For example, if I acquire 50 samples, I would like to know when each one was captured so that I can work out the time elapsed between them. Any help would be greatly appreciated.
Thanks in advance for the help.
Ming
(3,577 Views)
You get a timestamp whenever you acquire data as dynamic data (i.e. DAQ Assistant) or select waveform data type. The wavefrom data type is a cluster with a y array, a t0, and a dt. Assuming that you are using hardware timed acquisition, the dt is equal to 1/sample rate. If you are not using hardware timed acquisition, why not?
(3,566 Views)
Yes, I am using hardware DAQ. In fact, I am using DAQ Assistant. I understand what you mean. I think i figured it out. Thanks.
(3,538 Views)
