time table
Hi, I need to plot multiple data and put it into table with timestamp, but I found each data follow one timestamp, if the time column is same, how can I remove the redundant time column ( just show one time column)?
Message 1 of 10
(4,850 Views)
You could use the Delete From Array function to delete the first column:
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 2 of 10
(4,834 Views)
Looks like Steve beat me on this oneSmiley Happy
A quick fix would be to use "delete from array" function:
You could do this without the express Vi.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 3 of 10
(4,834 Views)
Thanks for the above reply. Furthermore question, if i need to delete column 1 and 3. Any simple method other than add a new "delete from array" block.
Message 4 of 10
(4,813 Views)
And how can I save the edited data in the tdms file (actually I am confused with the match of terminal type errors). Thank you!
Message 5 of 10
(4,809 Views)
You can use Write to Measurement File Express VI, Storage VIs or TDMS primitive VIs in LabVIEW to save data to TDMS files.
Message 6 of 10
(4,799 Views)
Thanks for your reply.
Error found when I connect the array w/ subset deleted pin to the signal of write to measurement file block, so what is the solution to solve the error?
Message 7 of 10
(4,792 Views)
Write to Measurement Express VI doesn't accpet the table data type as the input. I would recommend convert the table to 2D array or waveform and then wire it to the Express VI.
Message 8 of 10
(4,782 Views)
Does the input pin for data block is 2D array? I am still confused with the terminal conversion, anyone can illustrate that or provide a vi work example, thank you.
Message 9 of 10
(4,754 Views)
You can wire a 2D double array to the input, and to see what will happen 🙂
Message 10 of 10
(4,743 Views)
