time triggers A or B, HELP!
I am a labview beginner and I want to make a code that times automatically changes a set point. For instance from 6 am, set point A, if not set point B. I want to put it in a while loop to be a continues process.
Your support is highly appreciated.
Hoss
(2,272 Views)
Hi hoss,
so all you need is a loop with a comparison function inside.
What is your problem? Where are you stuck? Why don't you attach your VI?
So you probably noticed that "Training" section in the headerof this LabVIEW board?
(2,254 Views)
I hope you've noticed that Time is cyclic.  Consider what "after 6 a.m." means -- clearly 7 a.m. the same day is "after", but what about 7 a.m. the day before?  And what about 5 a.m. the following day?
Bob Schor
(2,240 Views)
