02-20-2007 10:35 AM
02-20-2007 12:29 PM
02-20-2007 03:37 PM - edited 02-20-2007 03:37 PM
Message Edited by Ed Dickens on 02-20-2007 03:37 PM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.02-21-2007 03:00 AM
02-21-2007 08:52 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.02-21-2007 08:55 AM
I added a time stamp that I linked to my signal (supposed to appear as a first column in the text file). I put a string to scale converter in between, to adapt to the format.
Of course, this might be the wrong icon: in the text file, the first column is added but no time displayed.
Do you have something to suggest? I am a bit lost cause no experienced...
Thank you.
02-21-2007 09:16 AM
Thank you, sorry for my last answer, we were writing at the same time.
The problem is that I can t open the file you sent because I have the version 8.0, which is older than yours.
I am trying to work it out, I let you know.
02-21-2007 09:26 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.02-21-2007 10:12 AM
02-22-2007 03:12 AM
To precise what is happening when I want to open the VI: there is a window asking to 'Find the control named Ex_userDefProperty.ctl' and it continues loading only when I click 'Cancel'.
So then I assume that I probably forgot to create a folder or something... I don t have a clue about what it is.
Do you have an explanation?
Thanks a lot
