timed condition (timed comparison)
Hello, just wanted to ask of a simple way to make a timed condition.  To be brief, I have a value which I want it to be greater than zero for "x" seconds.  If such value is greater than zero for these "x" seconds, then a boolean "true" value would light a LED indicator on.  However, if during these "x" seconds the value is equal to or lower than zero, even for a single second, then the LED indicator will have to remain off or in its "false" value.
Is there a simple way to make a timed comparison?  In advance thank you very much for reading and for posting your suggestions.
Best,
Nestor
(3,846 Views)
Accepted by topic author Nestor_C
Nestor,
Put all the values acquired during the "x" seconds in an array. Use the Array Min Max function.  If min < 0, then false.
Lynn
(3,836 Views)
An alternative implentation is basically to say that you want a VI which will delay a T value on a boolean wire (B) for N seconds. If you look at the Time Elapsed express VI, it gets you most of the way there. You basically just need to call it with Auto Reset set to F and wire NOT B into the reset terminal, then look at the result. If B is F, reset will be T and the output is F. If B is T, reset will be F and after N seconds the output will be T.
You might also want to give special consideration to the case where N<=0.
___________________
Try to take over the world!
(3,829 Views)
Excellent.  Thank you very much Lynn!!!
Best,
Nestor
(3,818 Views)
TST, Thank you very much for your alternative implementation!!!  Both solutions I've received work great!!!
Best,
Nestor
(3,814 Views)
Nestor,
Be aware that for non-integer representations of data, equality comparisons to zero will not produce a True output unless the value is exactly zero. If you do any calculations on the data you could get values on the order of 1E-16 which looks like zero on most displays but will not show as equal to zero on a comparison.  >= or <= comparisons are usually OK.  This probably does not matter for what you are doing now, but it is somethign you should be aware of for the future.
Lynn
(3,802 Views)
Got it Lynn, thank you very much for your advice!
Best,
Nestor
(3,786 Views)
