timed event inside event structure inside loop
Move that picture loop outside of your event structure loop.
Also, here is a simpler way to run that while loop and cycle through images.  You don't need a case structure for every case.  And you can get rid of the enum that seems to be there to "sort of" enumerate the case structure.
Message 11 of 14
(2,797 Views)
I've tryed your solution but still not working. I can't make each "event" (blinking and images slideshow) to be done in different time, 1 and 3 secs each.
Message 12 of 14
(2,785 Views)
Accepted by topic author salgadoc
You didn't try my solution because you didn't move the other while loop out of the first loop like I said.
See attached.
Message 13 of 14
(2,780 Views)
Sorry for taking too long to respond. I was on a business trip with no free time. You were very helpful. Thanks a lot.
Message 14 of 14
(2,740 Views)
