timed loop inside a while loop
Hi all,
I want to ask if I have a timed loop inside a  while loop ,  the timed loop  does a certain task  a 100 iteration ( each time loop iteration is 2 second duration) each while loop iteration  , at each  while loop iteration the time loop writes the actual time spent to a text file for this certain task.
for the next while loop, the timed loop contiues  to write the time spent from the previous while loop ( ex the first while loop the time loop ends the last results with 200 second for a 100  time 2 second duration ), the second while loop  the time loop starts 202 and so on)
I would like for the second time loop to restart  and start  again from 2 second and same for the third and foruth time loop )
attached is my program
Maple
(3,964 Views)
Hi Maple,
Can you please clarify what you are trying to do?  I am a bit confused by your post.  Maybe a table or a picture will help clarify things for me.
Ching P.
DAQ and Academic Hardware R&D
(3,924 Views)
Hello
yes , I will
thnaks alot
Maple
(3,923 Views)
Hi Ching
let me put my question in this way,
I have a timed loop, I want to run this timed loop  to perform an action for 2 seconds 100 times, I want to  write  to a text file the time counter for these  100 action ( i.e.) starting from 2 till 200 , if I will  put this time loop in a while loop to do the action twice, the timed loop starts  writing to the text file from 2 second till 200 for the first  while loop ,  for the second while loop it contiues from 202 till 402,
my question is how could I reset the  timed loop to start counting for the second while loop from 2 liked the first one
Hope I was clear this time
Wadah
(3,915 Views)
Hi Maple,
If I understand the question correctly, what you will need to write to file is not the Actual End [i-1], but rather the Actual End [i-1] minus the Actual Start [i].
Please try this out, and let me know if this is not what you were looking for.  Best of luck on your application, and have a wonderful day!!
Ching P.
(3,895 Views)
