Hi there,
I'm still trying to learn LabView here and I'm confronted by a problem.
I'm trying to build up a VI that has a timed dialog box with two buttons that tells the technican to press a switch.
My supervisor wanted it to be like 5 seconds that the popup dialog box is on, then goes onto the next swtich if there is no user interaction. All of this at the same time making a voltage measurement off the DMM (Agilent 34401A) to see if the switch is working within tolerances. Also, he wants two buttons that are required: "Continue" if the technician wants to continue if there is a problem, or "Stop" the program altogether.
For example: A dialog box come up and says "Press S1", at the same time, start taking measurements. Then without user intervention, goes onto the next switch and says "Press S2", measure voltage, and so on.
I've included the VI that I was creating and I know that it is not the right way to go. I was trying to use a timed loop to see if that would work, but it's all wrong.
Does anyone have any ideas on what I could do?
I would appreciate it.
Steve
