timed sequence with individuality for case structures
Hello All
The attached vi is one that I found by trolling on the forum, and made some slight modifications to it.
If you look at the BD, you can see that the timing between the action of each case structure is the same.
I would like to modify it even further and have each case structure have its' own individual time control.
I can do this by using a sequence and place a wait in each frame.
Would this method be both suitable and the simplest ( I have been giving some thought to using one case structure, but this solution eludes me at the moment)
Regards
Ray
(2,925 Views)
Single case, single property node, single wait.
(2,915 Views)
Aaah.....Dennis...very succinct.
Your'e a goldmine of LV solutions.
Kudos
Ray
(2,909 Views)
